steveo Newbie
Online Status: Offline Posts: 28
| Posted: Apr 02 2005 at 5:06pm | IP Logged
I just got a 05 SE and i love it, i got a great price on set on 22" rims. (Rim usually aren't my style but i figure it will look good.) Anyway will they fit with no rubbing and will affect payload capacity or towing because i do use it to tow my other truck. Also how will it affect the warrewnty cause i'm also having the brake problem as well. Thanx for the feedback.
__________________ Go big or Go home
bought2 Newbie
| Posted: Apr 03 2005 at 4:36pm | IP Logged
We bought an 04 XE with 6,000 miles on it recently. The previous owner put 22" chrome wheels on it. Shortly after we bought it we started having the vibration in the wheel. I took it in and the dealer machined and turned the rotors as well as put on new brake pads. He told me that they will not do it again for free because we put on the larger wheels and it could be caused from that. After reading the posts in the problems bulletin I know that is BS! If the problem comes back I will take the truck back in. I am hoping they just come out with a recall and fix it permanantly. By the way...the truck looks awesome!
__________________ Love em!
hipnotik Newbie
| Posted: Apr 03 2005 at 6:00pm | IP Logged
All im going to say is that 22's mess up your brakes. Silverados, dodge rams, f-150s, tundras, and titans are all the same in that once you get a rim bigger than 20s stopping your bigger wheel is more of a problem than one might think. Lets just put it this way... stopping with 22s is harder. Harder stopping on the brakes causes them to wear down faster. Go ask any rim dealer about the 22s. They will suggest getting new brake pads etc. Id say if the deal is really that good... buy them and sell them for more. Then go out and buy yourself some decent 20 inch rims that wont give you any problems
steveo Newbie
| Posted: Apr 04 2005 at 12:41pm | IP Logged
Well i appricate ur info guys i dunno what i'm gonna do it almost seems like i'm askin for problems but if the problem is already their what difference does it make. anyway about the brakes they have the solution comin out in May, any other suggestions let me kno.
rapineda61 Groupie
Online Status: Offline Posts: 93
| Posted: Apr 06 2005 at 11:06pm | IP Logged
I have a le 05 with 22" on it and I HAVE NO BRAKES PROBLEMS MY RIDE IS SMOOTH,now if you want to load truck and tow I think is not recomended becouse the type of tire that you have to use is a low profile is not god for work only for performance,breke problem I DONT THINK SO that is a recall on 04 ONLY ,05 THEY HAVE A BETTLER SYSTEM , i JUST TO HAVE A 04 LE CC WITH THE SAME WHEELS AND I had the problem now I got the 05 no more problems .So don worry brakes problem your not gonna get non,but for loading and towing dont do it .
05 LE CC 4X4 22 CHROMES MAGNUS AEM INTAKE ,GIBSON SINGLE SIDE SYSTEM.HARD SAME COLOR COVER, TINTED,check my pics I have both trucks
| Posted: Apr 06 2005 at 11:32pm | IP Logged
The brakes on the 05s are noe better they are the same as the 04s as
Nissan won't acknowledge that there is really an issue with all the
trucks. They seem to think its onyl a few and like to keep their head
in the sand until the class action id finalized. Then we will see them
really get to the issue. It happen on the G35s and Nissan tried to wish
it away and we got a 30k war added to our brakes. It just a matter of
time late 05s might get the 14 inch rotors but the 06s are getting them
and thats from Nissan to the dealers.
TitanPilot Newbie
Online Status: Offline Posts: 14
| Posted: Apr 21 2005 at 1:28pm | IP Logged
The size of your rims has nothing with the stopping power of your brakes, unless the rims are made of lead, but that's another debate. It's solely dependent on the overall circumference of the tires. If your tire circumference has changed, or increased, you will be adding to the radius (arm - length from the center of the hub to the outside diameter), and therefore decreasing the torque required to stop the vehicle. If you have really small rims on the vehicle, you will need much stronger brakes to stop the same amount of weight. Hope that clears things up.
bfit01 Newbie
| Posted: Apr 29 2005 at 7:54pm | IP Logged
Larger rims = increased rolling weight = harder to stop. It is highly recommended to put a bigger brake kit on any vehicle that you increase the wheel size 2+" more than stock.
thaimonkee Groupie
Online Status: Offline Posts: 88
| Posted: May 02 2005 at 5:36pm | IP Logged
i had 22 and had brake problems. just switch the 22's back to stock before taking it to the dealer so you wont have ot deal with there BS. i got 24's now and loving it.
