| Posted: Aug 09 2005 at 12:58am | IP Logged
Do you have the KC or CC? I'm wondering because, of course, the KC will give you a little more bed space....ok, no pun intended. I don't know what's legal or not on your side of the country, but all of that should fit.
Two options:
1. Stacking them, you would have to load the full size first, then the queen size on top. You would have to make sure they are extremely well tied down, to avoid wind draft from blowing the matresses off. And, of course, you would have to be able to adapt to using your side mirrors for the entire trip, and avoid driving like a bat out of hell. I've done this, but only for a trip across town.
2. If you went to stacking them on their sides, you would do the oppisite. Load queen first, full size second. I don't like this method for the fact of turing sharply can cause unecessary rubbing and tilting of your cargo, unless securly strapped down. Once again you would have to revert to using your side mirrors.
I don't know if any of this helps, but I'm just giving my input on my experiece moving with this truck.
