Subject Topic: Suspension Issue Post ReplyPost New Topic
Missle250r
Posted: Sep 23 2005 at 2:39am | IP Logged Quote Missle250r
I'm surprised no one has mentioned the suspension on the Titan as yet. I took mine in a few weeks back cause when I have to do a correction on the fwy there's an abnormal sway in the rear end. Normally a truck will fishtail one way and then correct. The Titan fisthails both directions before correcting. Also when I drive next to a vehicle of equal size the wind bouncing back at me moves me like I was in a small size truck. So I took it in to the dealer....after 2 trips. 1 for a day when they acknowledged it was an issue and unsafe but couldn't figure out the problem, then for 2 days for them to look at it again b4 they called out one of the nissan engineers to look at it. After the second trip they test drove another Titan and said it was "normal". How does something go from abnormal and unsafe...to normal in the matter of a week? Just because another Titan does it, may make it normal, NOT safe. Anyone else noticing this kind of problem, not to mention it tracks on the freeway like cr@*#.
Thing is I talked to my uncle about the problem, he had a buddy that had the same exact issue with a tacoma and found out Toyota was using too wimpy of a leaf spring causing it to control irratically.
Back to Top View Missle250r's Profile Search for other posts by Missle250r
pied_piper
U.S. - Oklahoma
Posted: Sep 23 2005 at 6:56pm | IP Logged Quote pied_piper
Can't say that I have had this problem. Have had my Titan for over a year with no problems.
Back to Top View pied_piper's Profile Search for other posts by pied_piper
Missle250r
Posted: Sep 23 2005 at 8:05pm | IP Logged Quote Missle250r
Nice to see it isn't in fact "normal" like I'm being told.
pied_piper
U.S. - Oklahoma
Posted: Sep 24 2005 at 10:27pm | IP Logged Quote pied_piper
As far as I'm concerened, my suspension is pretty tight with little give.
04titancc
U.S. - Mississippi
Posted: Sep 25 2005 at 3:38am | IP Logged Quote 04titancc
58k miles and no suspention problems.  drives like the day I got it except for the warped roters that are geting fixed tuesday.
Flowmaster 40 single in dual out w/turn downs
Back to Top View 04titancc's Profile Search for other posts by 04titancc
kcidmil
Posted: Sep 25 2005 at 9:32am | IP Logged Quote kcidmil
My advice, keep a visual record of the your tread wear.  If it becomes abnormal (sloping, feathering... etc)  take it back in and demand that something has to be fixed.    I can almost guarentee because of the fact you track, and fishtail, your tread on the tires are going to be jacked up.
Then Nissan will have to do something with it, because that doesn't happen unless something isn't aligned right, or is loose.  And they also have your complaint on file about the rear end.
Back to Top View kcidmil's Profile Search for other posts by kcidmil Visit kcidmil's Homepage
pied_piper
U.S. - Oklahoma
Posted: Sep 25 2005 at 4:44pm | IP Logged Quote pied_piper
I would also ask to test drive another Titan, and see if you observe the same problems on that truck as you do with yours. Have something to compare it to.
Missle250r
Posted: Sep 26 2005 at 11:32am | IP Logged Quote Missle250r
yeah, they took me on a test drive in another titan with the same set up. But I still do need to run down to another nissan dealer and see if they have one with my setup that reacts the same.
Mitch
Posted: Sep 29 2005 at 4:53pm | IP Logged Quote Mitch
Hmm is this your first pickup truck? The rear end of a truck with nothing in the bed is squirrelly if you try to drive it like a car. Im not saying your wrong but remember its not a car. It mite be your shocks?
Mitch
Back to Top View Mitch's Profile Search for other posts by Mitch Visit Mitch's Homepage
Missle250r
Posted: Sep 29 2005 at 11:57pm | IP Logged Quote Missle250r
nope, this definately isn't my first truck. I've only ever really driven trucks. And no I've never had a problem with any of my trucks before being squirrly whether the bed was empty or full. the way the vehicle handles is as if it has a 6+ inch lift and mud terrain tires...not like it's bone stock suspension. and they checked the shocks, supposedly, and said nothing was wrong w/them.
Anyone else get some extra survey from nissan...other then the normal one they send out? just got a second one in the mail, but it could be b/c I sent a formal letter in.
