titanwild Newbie
Online Status: Offline Posts: 28
| Posted: May 23 2004 at 12:07am | IP Logged
__________________ TitanWild
| Posted: May 23 2004 at 10:37am | IP Logged
This is totally bizaar, but I definately do not have that lever on my
catain's chair. So wierd too since even the original sticker says
I should have it. The manual doesn't specify it an an option
either.....did I get screwed? Should I contact the dealer?
| Posted: May 23 2004 at 10:52am | IP Logged
Titanwild:
Do you have captain's chairs or normal front seats? I cannot tell
from your pictuure. Catain's chairs have armrests on each front
seat that fold up or down near by the center console.
Let me know. Maybe the captain's chair option overrides the lumbar control?
titanwild Newbie
| Posted: May 23 2004 at 11:53am | IP Logged
Yep, My Titan has the captain's chairs with the center console. Its a King cab SE, 2WD, Big Tow, Rockford Fosgate, and Bed Packages. I would sure check with your dealer.. Looks like Nissan just flat forgot something!
| Posted: May 23 2004 at 11:56am | IP Logged
Man, I guess. totally weird. It isn't a big deal, but I
think it is strange to have captain's chairs that would come with the
lumbar as an option and not standard....
I guess I will have to call them. It is a minor detail, but is bugging me...
Thanks again for your help.
| Posted: May 23 2004 at 12:16pm | IP Logged
Check this out...took a coule pictures for you to see and give opinions on, if you have any.....
| Posted: May 23 2004 at 12:18pm | IP Logged
I'm going to stop by the dealer tomorro and show them this to see what they say....
Makes me think they'll have to order me a new driver's seat......
| Posted: May 24 2004 at 7:45pm | IP Logged
Just got back from the dealer. They were surprised too.
They are ordering a lever. If you look at the picture I posted of
my seart, it appears the control for the lumbar is there, the hole in
the upholstery and the lever are just missing.
They said they would just have to make a slit in the fabric and install
the lever. I told them I didn't want teh slit cut in a way that
would eventually allow the hole to grow bigger. (Usually holes in
fabric have some stitching around the outside to keep them from growing
bigger).
I'll keeo you posted. They didn't know how long it would take to get the new handle in.
titanwild Newbie
| Posted: May 24 2004 at 10:48pm | IP Logged
Yep, pretty much as I suspected, an assembly line error. I'd go ahead and let them install the lever, then watch it closely. Get a receipt for the work performed, even if it costs nothing.
Good Luck!
| Posted: May 25 2004 at 9:43am | IP Logged
I will. Incidentally, I already had to take my truck in once
before because they didn't install the bolts to hold my running boards
down.
I kept hearing this rattle and before I could take it to the dealer, I
happened to be washing it. I got to the running boards and lifted
them right off the supports...
I took it in and they special ordered the bolts and installed
them. Probably the same assembler that didn't put on my lumbar
lever
