Posted: Dec 18 2005 at 10:03am | IP Logged
If you have the navigation unit the entry/exit feature of the seat can be disabled, otherwise it's a dealer "fix".
My seat is also in the wrong position at times. Usually I think it's because I confuse it though. Since the seat starts to go to it's position once the key is put in the ignition, I think it can be fooled some times. It only happens to my seat if I put the key in, let the seat start moving, then start the truck before it's finished.
Usually I start the truck quick enough the seat doesn't have a chance to move till the truck is running. Or I let the seat finish it's adjustment after putting the key in, then start it, and never have a problem that way.
Don't know if that helps at all?!
