| Posted: Dec 29 2005 at 10:11pm | IP Logged
I just installed my volant air intake on Saturday the 24th. I made sure to disconnect the battery cable to reset the computer. Sure enough on my 1st city run I got 13.5 mpg (usual 11 or 12) and an amazing 18.5 mpg (usual 14-15) in my 4x4 05' king cab. I even siliconed everything off to make the system more air tight cause it wasn't what it should have been. The factory system is actually pretty well sealed straight in to the fender wall.
I heard from this web site that after 500 miles the computer somehow adjusts back to a stock "situation". The pat 2 days I have driven over 800 miles back and 4th from LA, to AL. I received 17.6 and 17 mpg yesterday. Today, the same hwy driving, after hitting the 500 mile mark, my mpg was 15.8 after 250 miles then 15.4 after 171 miles!!!!!!!!! (and that was more stedy driving)
It must be true about the computer after 500 miles!!!!!...................How can I fix this problem? What can be done so I won't have to disconnect my cable after every 500 miles. I will disconnect it tmrow and see if it is really true. I will be back on the hwy again. This motor can obviously be efficient but the truck is not tuned to be efficient. I have already had it put on the diagnostic machine and everything registered fine.
