Volocty Newbie
Posted: Feb 21 2006 at 4:13pm | IP Logged
Anyone else experience their LTPWS Light (Low Tire Pressure Warning System) come on after about 20 minutes of highway driving? Any long drive of more than 20-30 minutes (highway / freeway) and the Low Tire light comes on, and stays on until you shut the truck off. Doesn't seem to be Temp related.
chokoy Senior Member
Online Status: Offline Posts: 102
Posted: Feb 21 2006 at 4:38pm | IP Logged
do check ur tires. it might be a broken sensor or low tire pressure. if ur mileage drops then it is caused by low pressure.
Posted: Feb 22 2006 at 7:32am | IP Logged
If your tires or tire is low you may have the leaky valve stem. I think there is a TSB out on it. Here's a link:
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2004/NT B04-038.htm
May want to take it to the dealer and have them take a look at it. May be a bad sensor.
Posted: Feb 24 2006 at 8:50am | IP Logged
These sensors are like the crying baby at a restaurant: NUISANCE. But they can be easily fixed my checking tire pressure, and maybe going about 45lbs in the tires. I myself replaced the tire sensors with regular valve stems. No problems.
electricjohn Newbie
Online Status: Offline Posts: 22
Posted: Feb 24 2006 at 1:34pm | IP Logged
I am using my spare in the tire rotation scheme, and that causes my light to come on, but it takes more like an hour.
__________________ white 4x4 SE CC with big tow,pop w/capts, bed package,splash guards,and floor mats.
born on date 4/1/04
Clayton Newbie
Posted: Feb 27 2006 at 11:19pm | IP Logged
Mine do exactly what you're describing. But only when the temp's below 20 or so. The tire's are all at 40psi so I know that's not the problem. I just figured it's a quirk in the system. My wife's Murano does the exact same thing. What kills me is that she had a tire with a nail in it and only 18psi and the light didn't come on. I think it's kind of a half-baked system.
Johnathn
Posted: Feb 28 2006 at 3:55am | IP Logged
I also had the same problem...the dreader cold weather tire light. I've never found much of an issue with the tire pressure. My advice is to obviously consider it a possible low pressure situation but don't panic something about cold weather seems to freak the system out
