dboysb Newbie
Online Status: Offline Posts: 17
| Posted: Mar 08 2007 at 8:43pm | IP Logged
DOES ANYBODY KNOW HOW 2 ADJUST OR ALIGN THE FRONT HEADLIGHTS? MY FRONT RIGHTSIDE HEADLIGHT SEEMS 2 B HIGHER THAN THE LEFTSIDE.
__________________ SoCal TITAN
2005 Kingcab SE
TRUXX 3" Lift Level kit
Flowmaster 40 series
AIRHOG air filter
35"x12.50x 18 stock
Cooper Discover STT tires
Silverstar Ultra Vision High/Low Beams
| Posted: Mar 09 2007 at 1:13pm | IP Logged
There is a hex screw in the center top portion of the housing of the headlight under the hood. Adjust accordingly. I think there is a section in the manual that tells you what levels your lights should be at from certain distances. Beings you have the 3" mini-lift, you may want to adjust a little more than you would if you were riding at stock height.
