| Posted: Jul 01 2004 at 2:33pm | IP Logged
The Titan comes with both 17 and 18 inch wheels. The overall tire diameter difference is less than an inch. The 17's are 285x70x17....I think that the 18's are 265x70x18..you can look it up in your manual...
Either one will work...You can go to [http:\\www.tirerack.com] and check which tire fits each truck. You can select the model of Titan that you have. If you choose "offroad" it will show you the tires that fit the 17" rims. Otherwise it will show the 18" tire size.
Hope this helps
